Discuss G59 in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Up to the DNO... they'll tell you when you send in the application form.
Almost certainly will need it. Anything over 50kWp generally will. Speak to the DNO before you send off your design if you want to application to go through quicker.
And then speak to Andy O'Leary at Sibert Solar for the relay.
That is OK if your inverters are near the origin of your installation. But having a G59 inverter some distance away from the origin may give you voltage drop/rise issues.
Reply to G59 in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Can I install an RFI / EMI filter (designed to increase efficiency with a photvoltaic (PV) solar energy inverter) to an existing solar system...
I (well, the MCS installer) obtained approval under G59 back in 2015 for 11.5 kW of grid connection on a single phase. 12kW of panels into two 6kW...
Assuming a large company needed a large EV charging infrastructure for its fleet to be electrified. Would it be best to just go straight for 150kW...
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Hello everyone, I currently have two solar modules left over from an installation and I would like to use them to set up a solar system on the...
