Discuss ground cable for power windows in the Auto Electrician Forum area at ElectriciansForums.net
dangitnghia
hey guys sorry for the noob questions. im trying to convert my manual windows to power by using this guide. DIY: Power windows in a 96-00 civic DX
i have done everything except for grounding the cables and connecting a power source. I am currently stuck at grounding the cables. Do i cut the cable at the switch plug and ground them to the car or from the motor plug and ground them to the car (which connects to the switch)
any help is a appreciated. thanks
Those diagrams in colour,show where the grounding wires are. These need to be connected to the body or chassis. Do not connect these to the door body,where return path for current maybe oily hinge pins! just clean a small patch on door pillar say,and self-tapper a suitable ring terminal on.
Reply to ground cable for power windows in the Auto Electrician Forum area at ElectriciansForums.net
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
Hi gentlemen, I have three phase motor has an issue. This motor is star connection. When I just disconnect the power cable coming from MCC...
I have a box powering three 3-phase motors off of one 240V single phase line, NEMA 10-30. In the picture you can see a wiring diagram. The...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
My GF's daughter's 2010 four-door Elantra had a broken window regulator at the front passenger door. I replaced it. To do so, I had to disconnect...
