Discuss Guidance on home network wiring. in the Computer and Networking Forum area at ElectriciansForums.net
the audio side is simple. big f*ck off sound system in living room.Pink Floyd on endless loop, leave the doors open.
When I did our refurb, where ever we wanted a TV, I ran 2 x satellite grade coax, 1 phone line and 1 x CAT5. Our BT line comes into a cupboard by our front door - 1 then ran a single CAT 5 into the loft above the cupboard where I planned to fit the switch - then I ran all the other points back to this - we now have 12 points around the house, plus a backup device attached to said switch.
With CAT5 you need to consider where the incoming broadband is, and where you want to place the switch.
The loft houses all the coax cables - only 8 points are currently connected and this can handle multiple inputs too.
Wifi, is there for the mobile devices.....
If you do something similar, I would recommend 47mm deep back boxes......
Best start writing a spec for each and every room and take it from there...
what about this type of socket
WiFi Connekt 13A 2-Gang Switched Socket with Ethernet + 2.0A USB Starter Kit - https://www.NoLinkingToThis/p/wifi-connekt-13a-2-gang-switched-socket-with-ethernet-2-0a-usb-starter-kit/1571t#_=p
if you are short of space and don't want to use powerline adaptors
I've not used them so cant comment
If they don't work you can always charge yer phone via the usb whilst using it as a hotspot for wifi ..
Network wise decide where you want to equipment to be located, router NAS etc etc then cascade down the house from there, mine is in the loft and I also have a patch panel under the stairs to switch things over if need be.
Thanks for the heads up. Issue at the moment is where to locate any sort of switch Hub. I’m assuming that any wall plates will need deep back boxes.
With back boxes go as deep as you can. Idea being you can coil a little bit extra cable in there so you have scope to easily re-terminate if required or simply want to swap the fronts.
When I say a little extra 300mm or so wouldn't go amiss, especially when try to do the punch downs on the back you have more room.
I’m going to try and get some decent size trunking into the walls. Are there any cable support issues running under floor boards as I see that could be a good area to hide a bit of slack?
Reply to Guidance on home network wiring. in the Computer and Networking Forum area at ElectriciansForums.net
Hi all, I currently have a Pyronix Enforcer V10 Wireless alarm system. I have some shock/contacts on windows, doors, PIRs, and an external siren...
I have unexplained equipment and diagram for three separate connected f81 connectors. Each f81 connector is connected to single receiver to single...
Reaching out for some help/guidance and sanity check. Apologies in advance for the long post, but wanted to make sure it was clear. Thanks in...
Hi there, Just about to move into a house with 2 small kids and the wiring/electrics haven't been updated in years (hard to know as it's probate)...
