Discuss Had a cracker of a job today in the UK Electrical Forum area at ElectriciansForums.net
Oversleeving old cables just because they look ok is no different to going into a garage to have a new set of tyres fitted, only to find they've given them a coat of black gloss because there's still tread left, but charged you anyway. Just don't understand why the customer thinks this is ok.
Ive been to a couple of jobs where the customer has told me that they need a rewire, it then turns out that a new CU with a couple of extra bits (sockets, circuit or whatever) are all that's required.
Sometimes, they're over the moon at saving a couple of grand. Sometimes they doubt it can be so because "the other electrician said the wires need replacing because they're old colours". Pointing out that the current install is likely far better quality and standard than 'ripoff & leggit' are going to give them doesn't always sink in either.
I don't loose sleep over it, I'm an electrician not a moron therapist.
I've seen a few classic rewires with all circuits connector blocked behind the new board!! MESS!
i found 1 of them a while ago, in an old cottage. damp had got into the wall behind the CU and hence into a choc block extending the RFC. took me about 3 hours tracing the low IR reading from mid point. GRRRRR.
Reply to Had a cracker of a job today in the UK Electrical Forum area at ElectriciansForums.net
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
