Discuss Help with small lifting motor wiring? Where does the other end of this resistor go? in the Electrical Appliances Forum area at ElectriciansForums.net
My question stands though... how can you make the motor run and change direction with only two wires to the directional switch? There appears to be a wire missing from the diagram.
The diagram is definitely incorrect in that respect.
We'll probably never know why but maybe torque or speed limitation. Either way that resistor is likely to get pretty warm.
Unless it is only cap start in which case start up torque is reduced then it plays no part.
That was my thought as well. But if the diagram is correct, the cap would then only have one connection outside the discharge resistor. I'm also curious about the up/down switch as I don't see how you can achieve up/off/down (which I'm assuming is the operation) with only two wires.
The writing say up/down but it's wired as an on/off switch. I ignored the writing.....
Anything is possible but it doesn't look like a CSIR motor. It would need either a current operated relay in the connection box or a centrifugal switch on the back of the motor so it's unlikely.
If I'm reading the diag correctly - the cap is presently not effectively connected (?) implying the R is used in series to connect it (?) possibly to the top brown wire that goes to the switch. To avoid smoke, the next step is to understand the switch :)
Is there a circuit board inside that box in your hand? If so can you carefully slid it out and take another pikkie so we can see it.
That has also been doctored where it is using a green/yellow for a line conductor. I still think the resistor goes in series with the start winding because at present it connects to the capacitor and the capacitor must then connect to the winding. If I had it in front of me I would tinker with it but from a distance I couldn't say with confidence it has had too many alterations. I am sure a motor specialist would sort it for a small fee.
The more I see of this setup the less I like it. It looks like it could be a 230v stepper motor but I don't see any encoder feedback wiring. Maybe that's what the resistor was for, I don't know for sure though. Someone has definately adapted it to work in that application, it doesn't look like original fitment.
What was the original problem that motivated you to disamantle it?
The wiring going into the motor had rubbed through the lagging and shorted blowing the fuse I had to dismantle it to get the motor to a man that could fix it but I didn't take the switching unit / wiring as it was all connected to the bench still
If it's a stepper motor then I can't help, but if it's a single phase induction motor I have a thought, for what it's worth.
I think the R was in series with the C and they are used to create the phase shift in the 2nd motor winding needed to start it. (It looks like a diy mod - not happy ...). So the floating R wire should be attached to the top brown wire that goes to the switch. I've attached a diagram of what I've in mind. Please remember this is a 230V motor and the wiring is clearly in a distressed state and not suitable for use, in my humble opinion.
Thank you for all your help I think 'distressed' is too kind! Think a visit to my local motor electrician is in order!!
Wilko is spot on with his diagram. You can source the replacement resistor from:
Ohmite AG10J2R2E 2R2 5% 10W Audio Gold Wirewound Axial Resistor - https://www.rapidonline.com/ohmite-ag10j2r2e-2r2-5-10w-audio-gold-wirewound-axial-resistor-62-7388
and then ask the electrician to make the soldered fly leads to it and wire it to the connector strip. I have given you a likely replacement component but you must order using the details on the defunct resistor - all we can see is 2R2 or 2.2Ohms. You want the power rating and operating voltage off it as well but I reckon for the current flow (circa 1Amp) and the duty cycle (circa 5% or 12 seconds in 60 run time) a 10Watt rating and 350Volt is sufficient. Rapid on line or RS have a help line.
I think the purpose of this ad hoc addition is to allow the 220Volt motor to be operated on a 240Volt supply. Without it I think maybe the motor would run too fast for the application and exceed its rated winding current.
You might want at look at the SKF catalogue servo actuator and control catalogue:
http://www.skf.com/binary/92-27487/Actuator-Range-Catalogue.pdf
In it you will find at page 330 details of replacement single channel up/down switches. When I perused quickly though the catalogue but I could not find details of the motor you have - a MAGNETIC SHC 14 BAK 11 but a you might discover it with a slower read through or further Google searches.
All the above is written on the understanding you will employ a competent electrician or motor specialist to do and test the corrective work.
Reply to Help with small lifting motor wiring? Where does the other end of this resistor go? in the Electrical Appliances Forum area at ElectriciansForums.net
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
Hi all. I have a G40PSH (Greenworks 40v Long Reach Cordless Hedge Trimmer) which I have taken apart before to sharpen the blades. Only this time...
Posted this to the DIY section since I'm not a business or employee in this matter but it feels more appropriate (and might actually get...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
I have a 1 HP Dayton motor model 5k673. It is being replaced with 31TR91. Need help with wiring. I was able to confirm line (L1) abd (L2 230v)...
