Discuss Hot Element Wiring in Oven in the Electrical Appliances Forum area at ElectriciansForums.net
MubasoM1
Hi. How to wire the hot element in a fan forced Westinghouse POL662W oven. The one at the back not top. A photo would be great . There are 2 connections on top and one below on each side. I attached a photo of current wiring which started a short circuit. Thanks a lot
looks like it's a case of cleaning the terminals and fitting new spade connectors. not sure about the white wire on the right hand terminal.element needs to be tested for continuity and earth leakage.
You have connected the earth wire to the element and the live wire to the earth terminal of the element!!
Swap the wires circled, but note that by miswiring the element you may have damaged the thermostat and or oven timer.
Thanks a lot Freddo. It is exactly what you said. Thanks God no damage was done. It is working. What freeks me out is that theelement needs to be replaced every year. Maybe we are heavy users.
All over the internet there is only one photo on this so this reply will benefit many.
[automerge]1582754330[/automerge]
Thanks a lot telectrix
It was wrong wiring
Reply to Hot Element Wiring in Oven in the Electrical Appliances Forum area at ElectriciansForums.net
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi All, My 1 and half Smeg cooker recently tripped when using the main fan oven. It was during quite a long period of cooking a roast. We reset...
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
