Discuss How to find the main fuse rating? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Goody
I have a bit of hurdle; I couldn’t find the fuse rating on the main fuse box. Should I ring the DNO for this info? You see, I really don’t want to break the seal (law) to look inside. Thanks.
Simple answer, no. The EAWR's do not permit you to work live, so as long as you don't cause criminal damage to the seals (which funnily enough never seem to be there???), then no, it's not wrong to pull the fuse.
In my experience,a lot of cut outs don't have seals on them,but you have to be completely sure that it is safe for YOU to pull the bullet,i.e check the condition,how old is it? Better safe than sorry,and NEVER cut the seals on the meter.
Reply to How to find the main fuse rating? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
Folks, Is there any hard or fast rule on what should be on a plug/fused outlet. I am aware portable equipment - plug 😂. I recently did a PAT and...
