Apr 27, 2025
Red level, al
United States of America
Other
If other, please explain
I have some experience with plugs lights breakers but limited to pretty much “put in these receptacles “, “install this ceiling fan “
If I start a saw in one room (15amp circular saw) the lights in that same room brighten but throughout the entire house the power dims
You have a fault on the neutral conductor.
This could be anywhere between the utility transformer and your distribution panel.
Without the right test equipment, it will be difficult to locate.
Visually it may look like it has been overheating, discoloured, melted etc.
It is a dangerous fault that will certainly damage equipment that is plugged in to the 110v outlets.
Overheating or even fire could start at the location of the faulty connection.
Please get an electrician to look at this as a matter of urgency.
Red level, al
Other
If I start a saw in one room (15amp circular saw) the lights in that same room brighten but throughout the entire house the power dims.
DIY Electrical Advice
Thread Tags
Jrabonjr,
James,
