E
ElecEngineer
Can any one help..?
Having not installed any SWA before I’m about to undertake a job to install 6mm 2core cable to agarage. The cable would need to be buried for approx. 20m in the ground – whichI’m allowing to go 500mm deep. However it is when the cable first enters theground and when it comes out I’m concerned - remaining areas will be fixedevery 300mm onto concrete gravel boards etc – what mechanical protection would Ineed as it vertically enters and leaves the ground? To protect from strimmeretc.
Also I’m allowing for a IP65 rated garage consumer board withstandard sockets and switches - but are there any limiting factors ininstalling by windows and doors?
Can any one help..?
Are you another one of Dan's mates been sent to wind us up???
Reactions: 4 people
Gasp! A two core swa?!
What are you going to use for an earth facility?
That'll be what the metal coat hanger brayed into the ground is for.
Don't worry about it Trev - this guy is an ELECTRICAL ENGINEER - he knows what he's doing ;)
Reactions: 6 people
Anyone got a spare gasp I can borrow
It seems there's not many left and I could use one in another thread
I blame the overuse of double gasps lately
Reactions: 2 people
With immediate effect all gasps are rationed to ONE gasp per thread until further notice.
By Order of Desperate Dan.
Reactions: 2 people
Reactions: 1 person
:prrr:.........here's a rasp, then.
Reactions: 1 person
Can any one help..?
Having not installed any SWA before I’m about to undertake a job to install 6mm 2core cable to agarage. Good plan...who needs earthing anyway?The cable would need to be buried for approx. 20m in the ground – whichI’m allowing to go 500mm deep. However it is when the cable first enters theground and when it comes out I’m concerned - remaining areas will be fixedevery 300mm onto concrete gravel boards etc – what mechanical protection would Ineed as it vertically enters and leaves the ground? To protect from strimmeretc.
No mechanical protection required,but if you can find room on the DB apply a 'NO STRIMMERS' sticker. If not you will have to install another DB to accomodate it.
Also I’m allowing for a IP65 rated garage consumer board withstandard sockets and switches - but are there any limiting factors ininstalling by windows and doors? Same rules as sinks I believe....minimum 150 mm distance....(or is that gas pipes?)
Hope this doesnt help.
Reactions: 1 person
Done ... and I think I just have been, :(
Now thats how to negotiate a contract......quick and to the point. Who needs solicitors and accountants when we have geordie engineers.
Reactions: 1 person
...Once upon a time,there were twin brothers,one was very keen on earthing and went to work abroad....the other one.....
Reactions: 1 person
OK chaps, since I'm a bit late to the ridicule party, and it's not really my thing anyway, here's a sensible answer to the issue of cable protection on exterior walls (if required):
19mm x 19mm Cable Guard - 2Mtr Length - Black
Reactions: 2 people
A TT system from at the garage end! - which is considerably more reliable than trusting 30m of CPC buried in the ground
Hmmm, Really?? Well if you say so, it must be right!!!!! I'll now have to re-evaluate the 100's of thousands of metres of cables i've had buried under the ground over the last 40+ odd years!! I guess the vast majority of all the other Electricians and Engineers will have to do the same now too!!
Reactions: 5 people
well with all you experience; is TT earthing arrangement on the garage end not sufficient - The steel armour will obviously be earthed at the CU (with RCD)
You're digging yourself an even bigger hole now, ....why would you have an RCD at the supply end, when you're installing SWA cable?? Are you not installing a garage RCD CU at the load end of this cable??
I wouldn't install a TT system at a garage, unless their was no other way other than to TT it.
Reactions: 2 people
Why don't you trust a CPC buried yet will quite happily bury 2 live conductors?
the way I see it - you could do it either way - I plan to use a TT earthing arrangement at the Garage end - Are you saying this in some way is not effective?!
Not really - I obviously plan to use a RCD unit in garage - I know this may cause both house and garage to trip but I want RCD on the Garage board and we all know the SWA must hav RCD protection...right!
I'm gonna say at this point this is a definite wind up. If not, put the tools down and get an electrician in.
Reactions: 3 people
oops :smile5:
Installation of SWA cable
ElecEngineer,
GLENNSPARK,
