Discuss Inverter on earth stake? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Been asked to replace an old consumer unit, PV installed so bonding etc up to scratch.
House supply is TNCS, however with the PV wiring the inverter (Fronius) is on its own earth stake! So that makes 2 earthing systems in close proximity! Why would they want to earth stake the inverter?
Depends when it was installed, are you sure it is the inverter that has it's own earth rod, and not just an earth rod for the array mounting system.
Where is the inverter mounted? How is it connected to the grid?
Yes, sure its just the inverter, clearly shown in the schematic as well. As you I thought it may have been for the array at first.
Inverter is in garage, connected via a 'Garage CU'.
Reply to Inverter on earth stake? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We don't normally do PV, however I was called to a PV inverter with no power, 6 years old Found supply OK, however fed through a AC type RCD. PV...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Hello there I have just installed a new Solis S6-GR1P3.6K-M-DC Inverter - this replaced a 10 year old+ Sungrow inverter that failed/out of...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
