Discuss Is it likely to be a light ring circuit? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bearlyable
In the process of changing a CU Ive discovered the lighting circuits are using 2x 1mm Twin and Earth though Iv not invetigated fully at this time is this likely to be a ring light circuit, if so is this common and how should this circuit be tested??? If not is it likely to be a radial using 2x wires and therefore do I treat them as 1 x wire???
Any info would be apreciated.:confused:
it will be 2 circs you need to split them up in the new cu and test them seperatly
unless 1 is lights and the other is emergency fittings then keep them together to keep emergs on local circ
2 lighting circuits on 1 breaker i presume mate.Never heard of a lighting ring:confused:
Reply to Is it likely to be a light ring circuit? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
I've tried to research and form a plan without asking on here, but I'm just going around in circles. Just completed an EICR. The wiring ranges...
