Discuss Is there an inverter that fullfils these requirements ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
donnib
Hi,
I want an inverter which can give the consumer power from solar if available, second battery if there is power on it and at last from the grid BUT i am not interested to feed to the grid (not interested in getting an approval from the local energy company). I know there are hybrid inverters but as far as i understand these will deliver from the grid thru the battery but that will destroy the batteries during winter when no sun is at my location so i want the inverter to switch completely to grid when there is no sun or power left in battery bank.
/donnib
I have used this inverter- they do other kW ratings too - which has 'Output source priority' which is pre-selectable. It is not designed to feed back into the mains supply. I think it might be what you are looking for:
- Output source priority: This intelligent feature allows the user to set output source preferences (solar/ battery power/ mains input or a generator) for the AC load output of the inverter. This menu includes several options for varying conditions and scenarios, e.g. which source of energy is given priority for the AC output if solar power is insufficient/ if battery voltage is too low/ if mains is unavailable, etc.
Reply to Is there an inverter that fullfils these requirements ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello everyone, I'm currently working on a project to upgrade an existing renewable energy system and could really use some expert advice. The...
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
Hello all, To avoid too techy questions, i am the consumer not he installer. I have raised the issue with my installer who is researching it...
Hi All, Main issue is as per title: inverter is stuck in Off-Grid mode. I used Self Use over the summer, which worked well, priority PV order...
5K
mididoctors
M
I (well, the MCS installer) obtained approval under G59 back in 2015 for 11.5 kW of grid connection on a single phase. 12kW of panels into two 6kW...
