Discuss is there much difference between these panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all,
is there much difference between these two panels , thing is segen dont have the N series in stock but have the other
Sanyo HIT 240W HDE (HIT-240)
Sanyo HIT N series 235W (HIT-235SE10)
thanks
Grand
Their physical size is different and from memory the N series use a higher voltage. Have a look for their datasheets to check this out.
N's have 3 bypass diodes each covering 2 columns of cells (portrait mode)
H's have 3 bypass diodes covering 4 rows, 2 rows, 4rows of cells (portrait mode)
Also some people like to shout about what they're doing so will choose the H series because of their aesthetics.
Sorry if my description was lacking. On a rectangle you have two short edges and two long edges. The four clamps will have to go on the two long edges. So two clamps on each of the long edges.
Hmm, it's a bit tricky to use words, shame I can't draw a picture on this forum.
Reply to is there much difference between these panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello Is it possible for solar panel monitoring to over state the actual power generated by the system? My friend’s 6.4kW system has generated...
Hello, I don't know if I'm in the right place for this publication, I apologize first of all. I did a search, but I didn't find anything.... Does...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi all, any advice would be greatly appreciated. Went to do some work at a factory unit on Monday ( changed 20 florries to LED battens and changed...
