Discuss landlords certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
wannabesparky
can someone please tell me how much roughly it would cost to have a landlords electrical safety certificate please, ten circuits in the board.
thanks
answered on your other thread. that's 3 on the same subject.
done properly, a pir should take 4 -5 hours. including writing up the cert. £150 - £200 is about the going rate.
Reply to landlords certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Private tenant since 2011. First ever eicr February 23 informed via text it failed by text from electric secretary arranging appointment for...
Hi, Hoping someone can clarify for me. I've recently moved into a rental property, the landlord had new electric radiators installed and a new...
I own two flats with a small common lobby. Although operable from both flats, the common lobby light appears to be wired to flat A's circuit...
Hi, me again :) NICEIC prices per certificate are going up, can you recommend anywhere else to buy them please?
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
