Discuss Light must be on for bathroom fan to work. Can I rewire so each switch works independently? in the DIY Electrical Advice area at ElectriciansForums.net
Left switch is blue and red wire. Fan had red and yellow and blackSo the left switch is the one with the yellow and black wires? Is the other switch the fan?
That did it! Thanks so much for the response! I fed the red wire into the back of the switch associated with the blue wire. Again, thanks so much!With what’s been said, it looks like blue is permanent live, switches onto the red which is then split between going up to the light and feeding the second switch.
if that’s correct, then all needs to be done is move the red feeding the second switch from the light switchwire onto the permanent live... in this case, blue.
The red wire nut twisty thingy looks like a bit of red conduit coming out the wall. Took me a minute to realise it was a twisty nut thingy
That did it! Thanks so much!With what’s been said, it looks like blue is permanent live, switches onto the red which is then split between going up to the light and feeding the second switch.
Reply to Light must be on for bathroom fan to work. Can I rewire so each switch works independently? in the DIY Electrical Advice area at ElectriciansForums.net
