Discuss MCB TRIPPING WHEN TRYING TO OBTAIN ZS READING in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Farmelectrics
HAD AN ISSIUE WERE THE MCB WAS TRIPPING WHEN TRYING TO OBTAIN ZS READING TESTED METER ON OTHER CIRCUTS ALL OK TRIED DIFFERENT TESTER STILL TRIPPING MCB WHEN CARRYING OUT TEST CIRCUT IS ON AND ALL HEALTHY WITH MARTINDALE PLUG IN TESTER GOING TO SWAP MCD OVER IN MORNING ANYONE HAD SIMILAR
not had this before if I'm honest had the rcbos tripping when the d lock isn't on the meter but not an mcb . circuit is on and healthy so no issue until you try and obtain a zs reading there is other items plugged in but cant see that causing any issues as it hasn't anywhere else. going to try and change breaker in morning
Change the breaker. Under normal use, the thing will trip way below it’s 32A rating.
does the switch not feel “soft” as you try to reset it?
the mcb was a 32amp merlin gerin supplying an office ring main yes there was kit plugged in why I was testing however this has never caused an issiue before. changed breaker and know I can get the zs without the mcb tripping strange never came across this before however all sorted
Reply to MCB TRIPPING WHEN TRYING TO OBTAIN ZS READING in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
Hello, I’m testing some electric meters. As the circuits have no load on them to prove each ct I’ve plugged a hair dryer to simulate a load and...
