Simple question but maybe harder to explain.
Whats you take on resetting a Mccb say 100 amps 3p@ Main panel board.
You’ve been called Out to a DB TPN, that’s got no voltage to it,you look inside DB,seems ok,& by experience you can see a reason why this happened.
You find the MCCB & reset,go back to DB, test voltages,switch mcbs back on.
Everything is now ok.
Would you suggest FI & maybe monitor the situation.
i find it’s always harder to explain to the client.
