Discuss minor works certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I
iceman
hi im tryin to get me self ready for my assesment with the nic on the green minor works cery where there is a box it says rcd BSEN my rcd is a 4293 im not sure wot type it is tho i think its a type B is this right thnks
no its not tht fuse m8
the fuse i got is a rcd BSEN 4293 THN in the next box its askin type ? this it wot im unsure about thanks
That the old BS no. New Rcds are Bsen 61008,Rcbos,61009, If its and older RCD and it stii functions correctly and complys to current regs i would score out the en bit and put in the BS No
I think that you are confusing the rcd for the circuit protective device. The rcd is a BS4293, whereas the mcb will probably be a BS3871 i.e. Type 1, 2 or 3 - or possibly a BSEN60898 Type B, C or D depending on the model/age of the consumer unit.
Reply to minor works certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
After a bit of advice as it seems starting from scratch and becoming a member of NIC or similar has mixed reviews on here.... Looking at starting...
Hi guys just looking for a bit of clarification. Im about to start a job in a kitchen thats being renovated and theres a couple of electrical...
Hi, I am currently studying/training to start a career as an electrician and i have recently finished my C&G Level 2 and currently studying for...
