Discuss New patented electrical outlet in the Electrical Tools and Products area at ElectriciansForums.net
I think it might be intended to be mounted lower down like where a flex outlet would be. But fed from an isolator switch above.
Cord grip is raised above plate level, so I suspect a cover is to be placed over it.
The inclusion of a 13A socket outlet led me to believe this was intended to replace the old fashioned cooker isolator/socket combo, but perhaps it is intended for used behind oven or below hob, with socket provided for gas igniter or microwave as previously suggested.
I need to get hold of a better imagination.
Yeah I think definitely that's the case. Just replaces a single socket and flex outlet. Still needs an isolator above.
Needs to be pretty cheap.
In parts of European 3-phase land, they like to plug cookers in with 5-pin Perilex plugs, or the Swiss or French equivalents. Usually 16A or optionally 25A, if the cooker shares the load reasonably evenly between the phases, the 16A plug gives the equivalent of 48A single-phase, or 32A if only two phases are used (leaving the the third for the oven). In single-phase installations, there is an unofficial re-purposing of the Perilex as 2 x 16A by connecting the L3 pin to neutral instead. Russia has a dedicated 3-pin cooker plug rated at 25A, so rather less useful but purpose-made with a flat design to fit behind a cooker.
When you have wired a cooker to a Perilex with nothing heavier than 2.5mm², our system that involves beating 6.0 or 10.0 into submission and/or then finding your oven has a 2.5mm² flex intended for a 16A circuit all seems a bit random. Also what we really don't have a neat solution for is the significant number of ovens that require a circuit fused at no more than 20A, but more than 13A. These are often intended to be plugged-in with a 16A plug in Europe, but as we don't have a 16A domestic socket in the UK we end up hard-wiring them, perhaps paralleled with the hob on a 32A circuit and conveniently overlooking the requirement for 20A max OCPD.
It is possible to design a relatively cheap but reliable 32A or even 40A connector with a low profile, if high insertion force and limited insertion cycle life are not important. If the OP wants to revolutionise cooker connections, how about a dual socket face plate with two 32A low-profile connectors that can accept 6.0 T+E or 5-core 2.5, with the option to fuse one down to 20A with a cartridge. A bridge too far? People said that about RCDs.
Like I said
I know, but I was trying to see what the major revelation was about it. I can't see anything groundbreaking apart from not having to make the short connection between a 13A socket and a flex outlet.
I think it is a good idea if it will fit on a standard twin box.
I hate squeezing into a base unit and fighting with multiple cables trying to wire a socket and outlet for a gas ignition hob and 6kw oven or 6kw hob and 2kw oven.
If as said above it is reasonable price and it cuts down the time on installation I'm all for it. Did I mention I hate being crammed into a base unit! 😀
As mentioned above what we really need are lower profile higher current sockets and plugs for internal use.
The jump from 13A to 16A commando in terms of physical size is just silly!
Back to the round pin 15A plugs maybe? They were ahead of their time!
They are still in fact available. BS546 is still a current standard!
But what I'd like is a 20 amp small internal socket, maybe with triangular pins just for fun....
Does anyone no of companies that will manufacture our new patented electrical outlet that will make installing cookers and ovens are far easier job for all concerned.
Regards
Michael
Depends on what type of patent you have etc. if its not a bad idea... sell the Patent and walk off into the sunset . But if it is the outlet shown in the thread? If its any good , The Chinese will be all over it . "patents " mean nothing there . The cost to fully patent things costs a fortune .I owned a full patent that was established after 2 years .It cost £5k almost to the pound in 1992. I Then sold the full rights for £22k . I knew I could never fund the concept . But someone would want it and they did . And for them it was peanuts . Not a bad profit .Purchased a 20v Audi "UR" with the money !
A lot of that is to do with IP considerations, more than rating. A company called Neutrik attempted to take that problem on with a range of connectors that are IPx5 16-32A and literally about the size of a fat thumb but they've only ever really caught on in the events world, and even then only as final connectors. Power - https://www.neutrik.com/en/products/power
Reply to New patented electrical outlet in the Electrical Tools and Products area at ElectriciansForums.net
Hi, Hoping someone can clarify for me. I've recently moved into a rental property, the landlord had new electric radiators installed and a new...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Has anyone heard of company called Scimark making domestic switches, outlets etc? We live in a house built by David Wilson Homes who...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
