Discuss Niceic certification in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Senior moment would you just fill in the Rcd section when fitting a RCBO
Er, actually you'd be filling in the overcurrent section as well for an RCBO. Otherwise there'd be no record of the current rating and overcurrent curve for the device.
Yea I wondered that, so confusing sometimes, like this on a MWC
That is correct although I would just quote 61009 to the left without all the other details, they go to the right as you have done.
Reply to Niceic certification in the UK Electrical Forum area at ElectriciansForums.net
Hello Got a customer who needs certification for a monthly emergency lighting test. What would be the best cert to provide them with? The NICEIC...
Hi, me again :) NICEIC prices per certificate are going up, can you recommend anywhere else to buy them please?
2 questions.. 1. Will the mini Starbreaker RCBO's fit in this board? Below is a picture of the board and also the type of RCBO I want to fit in...
I note that in answer to another EV Charger question a member suggested a 40A breaker would be preferred to a 32A because of many hours at...
Hi all I have been pulled up by Napit, not by my regular inspector. Used rcbo's on a rewire (usually do). Filled out cert to reflect this, with...
