Discuss No bathroom RCD in the UK Electrical Forum area at ElectriciansForums.net
Well, birds twiting (??), rain pattering, wife up and down, I'm off to bed and I don't give a ---- cos I aint got a bathroom extractor!!!!!! And If I did I wouldnt have an isolator or a 3A fuse and ***k the regs.............good evening.
fit a fan pull cord isolator switch if you want local isolation in the bathroom just shorten the pull cord so it is not used to turn on & off lights but is reachable by adults to turn it off over night if they wish, no need for a Neon switch, these units are 3 pole & also have an on-off indicator on them, went to a nursing home years ago loads of fans installed direct off the lights & no means of isolation to the unit, installed these units made the job nice & quick and reasonably priced.
as for the RCD unit if you are only doing work on the fan & it is outside the bathroom then not really an issue.
if you are really concerned then I would say take the feed for the bathroom itself that the fan is powered from into a cupboard if available on the landing or close to it if possible & install RCD fused spur in there, at least if the RCD unit goes they don't have to get in the loft. fan isolator pull cords that i bought think were about £4.00
Reply to No bathroom RCD in the UK Electrical Forum area at ElectriciansForums.net
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
Hello I have an old timed extractor fan in the bathroom which has stopped working. It has 3 wires which are black, brown and grey. I believe that...
Hi All, Weird matter happening here and I hope you can help! My 3 Pahse EC Fan is connected to a sensor and a controller for the temperature...
Hi all, I'm refitting my bathroom in my first floor flat (top floor) built around 1989. It has 2 CUs, one for night storage and one for 24h...
4K
Hi to all, If extractor fan in bathroom is autonomous does it still require isolator switch or usual fused switch will do? It runs of 12v...
