Discuss Noob Question need help help on old mode of multimeter in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
T
Tan Kok Lim
I recently bought a Uni-T multimeter, Press and hold power button to enter into Hold mode.
Can someone explain to me what is hold mode of multimeter and what is stand for Hold mode.
TQ
you put the probes onto what you are measuring. trhen press the hold and it keeps the reading after you take the probes off. very useful when you can't see the reading at times. so with hold, you can look at the reading after.
Reply to Noob Question need help help on old mode of multimeter in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hello, I have an all-in-one washer/dryer unit and it is giving me error codes. I have the manual that describes how to test the various...
I need to calculate the service ampacity of a building. The wire is 250MCM (copper). 3 wires coming in. These wires provides power to 6 - 60amp...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
