Discuss Problem with LED GU10 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
silentboarder69
Hi,
I've installed two LED GU10 lamps in a customers bathroom. They're on the same circuit as two fluorescent energy saving lamps already installed in the bathroom. So far, three LED lamps have blow (I replaced the first one, and now two have blown).
Could the motors in the fluorescent lamps be causing an over current and blowing the LEDs? Or is it a bad batch of LED lamps? I got the LEDs from TLC, and so am pretty confident they are good quality.
Many thanks,
Rick
may well be the cfl's are causing the problem. replave them with retrofit LEDs. also make sure there are no wiring faults.
Hi,
Many thanks,
Rick
Do they rotate, or do something fancy?
Reply to Problem with LED GU10 in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I have a downstairs toilet with two spotlights. I have recently replaced the MR16s with two GU10 LEDs. This has meant that my PIR makes the...
Hello everyone and thanks in advance! So, I installed this LED fixture in my bathroom to replace an old fluorescent fixture that had a bad...
  • Locked
5K
Hi there I’m looking for some help as I have what seems to be an electrical issue. It seems to relate to my computer PC, the fridge freezer in my...
