Kevin51
Watford
United Kingdom
If other, please explain
Retired Electro/Mechanical Engineer but registering here as diyer/ home owner
I am diyer retired mecahical engineer so not a sparkie. My son/gf bought a portable A/C a few weeks back due to the heat. It was bought from a reputable supplier. Called me today did I have any fuses. Yes I have spare fuses, why do you want a fuse. The A/C keeps tripping out the flat. Explained it wasn't the fuse but as the A/C is brand new didn't think that was the problem. Suggested they tried it in another flat and see if it trips there.
I was just registering here to ask suggestions when I got a call back from my son. They solved the problem, for some reason today they plugged it into an "adapter" for some reason not directly into the socket. I told them to throw the adapter away.
But just to satisfy my curiosity, the A/C is going to pull a lot of power so not a good idea to run it through a shared adapter but could it be that two lower power devices would not trip the supply due to a fault with the adapter and running an A/C crosses the threshold and trips the supply?
I would have though even one or two low power devices should trip the supply or did they by plugging in the A/C just blow the adapter up?
The other devices in the adapter could have been class 2 devices and the a/c class 1. A portable a/c does not really pull that much power, but yes i have come across faulty adapters so good call to ditch it.
Watford
United Kingdom
RCCD tripping but subsequently found the problem
DIY Electrical Advice
Thread Tags
Tags Tags
problem
Kevin51,
plugsandsparks,
