Discuss Regs on UG cable depth and marking in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i have had situations where you cant get the cable deep enough have always used marker tape and indicated that the cable is below the surface with engraved signs at each end
That's the way it should be done. As for the NIC inspector saying all was fine, I just don't believe it. Alteration work starts today!
T
Tafia, I think in your position I'd be pretty bloody minded right now and wanting to prove the point. Why not isolate the circuit and get a pickaxe out, couple of good swings and I'd bet you'd have the cable in your hands.
Aye, I know the cables are only few inches down with no tape or tiles: chap admitted it in writing, though I doubt he told NIC inspector who, the sparky claims, said the job was fine.
Maybe stand back and see what happens. You have made your point, but been overruled by everyone else.
Cheers,
Having been tasked by the council to deliver the cable route plan to the church authorities, I handed it to the church wardens on site who have placed it at the mains position as suggested by the sparky.
As you say, we will see what happens.
At our last meeting, one councillor , a friend of the sparky, when I again raised the issue, pointing out that the admission of wrong doing was not in the minutes, immediately jumped in and said: "What's the problem, they will find the cables right away with a metal detector"
This same chap, a builder, told us at an earlier meeting that a couple of years ago he had dug up and damaged a gas pipe. Gas board came out and told him the repair would have to come out of his builders insurance. He replied with the usual: **** off, that pipe was not deep enough and there was no tape above it"
See what I am up against?
Will let the forum know if I hear of any damage to the cables.
Thanks to all for your help. It is much appreciated.
T
Reply to Regs on UG cable depth and marking in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
Hi, I am a mechanical engineer tasked with some electrical engineering scope of work and not sure where to look for information on the...
Hi, this is a repost of the initial in diy as the only potential diy aspect is the prep ahead of a qualified person attending, this is hopefully...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
