Discuss Replacing fuse box query in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
mdovey
Just a quick question (I hope).
The house fuse box is an old wire type. The solar panels currently have a dedicated RCD/MCD fusebox fitted nearby.
If at some point in the future, I get the house fuse box replaced with an up to date RCD/MCD style, is it possible to replace both with a single box with both the house fuses and the solar fuse, and if so would the electrician need to be MCS registered? Would I need to update my FIT registration or inform the electric company I'm registered with?
thanks,
Matthew
Yes, that wouldn't be a problem and the electrician would not need to be MCS.
You must make sure that the electrician does not fit the PV system to an RCD unless he has to - and if he has to, make sure it is a seperate RCD to the rest of the circuits.
Reply to Replacing fuse box query in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Had a new unvented Boiler fitted as the old one had reached the end of it's life. Electrician mentioned that it might be worth replacing my fuse...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Greetings, I have a solar 5kw system installed with a hybrid inverter (no batteries yet). My electrician decided to add an extension board for the...
5K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
