- Aug 12, 2017
- 14,310
- 20,710
- 3,557,381
- 51
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Post in thread 'Safely Disconnecting Battery String' by ampsie has been reported by littlespark. Reason given:
Content being reported:
Duplicate
Hi All,
I'm moving into telecoms and looking for some help on disconnecting battery strings.
I come from a domestic background so have not got involved in battery strings before as I never touched solar.
My questions is thus:
How do you safely disconnect a battery string that is housed in a tight earthed/grounded rack? If there is minimal space between the battery terminal and the earthed metal of the rack.
I have been advised to disconnect the negative first on a short course I have undertaken but if you were to touch the cable to the rack whilst it was still on the battery terminal this would cause a short wouldn't it?
Am I correct in assuming this would not be the case if the fuses have been pulled and the negative cable has been completely removed from the negative battery terminal?
I apologise if this is a rookie question - just looking to arm myself with as much information as I can prior to entering the industry.
TIA.
