Guffer
- Reaction score
- 7
Hi
There seems to be some confusion at work about ring circuit continuity on an EICR. I was under the understanding that you took r1 & r2 added together and divided by 4, then during the live testing a Max Zs was measured using meter. The method two or 'figure of eight' is used only on Initial Verification or where there is no supply present.
This appears to be reinforced in both the old periodic and the new EICR dvd's created by the NICEIC where Tony Cable and his sidekick confirm that the figure of eight method is not requires on an EICR.
Why then do supervisors and inspectors insist on this method being used ?
Anyone able to enlighten me.
It appears to be the age old politically correct method v the financially viable method again !
Regards
Guffer
Regards
Guffer
