Discuss Ring Doorbell Pro Install in the UK Electrical Forum area at ElectriciansForums.net
Hi,
We live in a new build property which is nearly two years old. Currently have a mains powered Doorbell Deta C3501 with built in transformer.
Have purchased the above Ring Doorbell Pro and need some help installing it. The current setup has power brown/blue going into a connector block on the Doorbell. The push button is using some Cat5e cable going to the outside button.
It shows Deta C3501 A/C 220-240V - 50hz
Image attached.
Any help is much appreciated.
I think the voltage required is AC but that existing door bell output is DC.
I am sure you need to purchase the extender chimer and also keep your battery charged at the door end.
get the wifi extender chime and a 2nd battery
Reply to Ring Doorbell Pro Install in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Amateur with no experience here - bought a Ring doorbell in the sale assuming I would just switch it out for my doorbell by removing and...
Hi, So I ended up with a Ring video wired doorbell instead of a Byron video wired doorbell as B&Q were out of stock (had ordered online) and they...
Hi, I purchased a Time twin strand bell cable with a rating of 12-30V, 2A, low voltage, not for mains use. I wish to use this for installing our...
DIY’er here, so be kind. I am after some advice on fitting a wired doorbell in the UK. I plan on removing the current chime and replacing it...
