Discuss Smoke detectors + 17th edition in the Australia area at ElectriciansForums.net
i'm a bit confussed, can a smoke detector be protected by an rcd on the smoke detector's own circuit. if the smoke detector has its own battery backup, can it be still be protected by rcd. Part P does state it should be on its own circuit, but should it be RCD protected. I'm thinking if if was and the RCD tripped and the battery was dead, then that smoke alarm would not work.
smokes only require RCD if the cable/s are buried <50mm deep without earthed mechanical protection.
I understand the Logic in this, But irrespective of where the Smoke detector circuit is placed it still has to have a means of isolation of its own..So surely the circuit could be turned off anyway???
Not so. This 'advice' is in AD-B, where the wording is 'should' not 'must'. Anyway you could still take the smokes supply back to the MCB and label the leg - not easy for the average owner to 'turn off' but still complies with AD-B advice
Isolation for smokes can be achieved by removing them from the base, or unplugging them.
No need for a separate isolator.
Talk about thread resurrection!
Reply to Smoke detectors + 17th edition in the Australia area at ElectriciansForums.net
Doing work in a house the other day, and noticed they didn't have any smoke detectors... (well, one.. and it was a small 9v thing) So ive sent in...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
Hi all Recently we've been having a few issues with smoke and heat detectors.. been fitting them for years and years now mostly without any...
