Discuss Sub panel wiring directly to main panel in the DIY Electrical Advice area at ElectriciansForums.net
jaytee69
I live in las vegas nevada. I'm installing a sub panel outside that will be a 125 amps.I want to run the right wire from my sub panel to my main panel.My question is do I have to put a 125 Amp circuit breaker in the main panel and run the wiring to that. Or can I run the wiring from the sub panel Directly to the hot and ground and neutral wire locations in the main panel?
Reply to Sub panel wiring directly to main panel in the DIY Electrical Advice area at ElectriciansForums.net
I have an interesting scenario that could use some feedback. I have 200A service in my home with a sub panel running to a detached garage...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I have an outbuilding a fair distance from the house. In this outbuilding I just want to have some lights, a small music radio/clock, and a...
Hi all, Great to of found this forum. Much respect for keeping everyone safe! My background is in commercial data and Audio Visual. Been...
