H
haptism
Hi hope someone can advise; ive not done alot of testing or filling out eic's and am a bit stumped on this. I have run the usual dead tests on a 3 core swa cable used on a final circuit all tests are good. However the amour (which needs to carry the full fault current), does it not need to be accounted for its continuity on an eic ? For example if there are 4 sockets on a radial wired in swa it would be possible to forget to link out each pair of banjo's.
So do you calculate the resistance of the armour (although I know this would be up to standard if its smaller than 50mm or something), or do you just tick a box confirming continuity. I cannot find any info on example eic's where this situation is accounted for, so im probably missing something and would like to find out ! Thanks
H
H
