Discuss Terminating unused blue wire at the thermostat in the DIY Electrical Advice area at ElectriciansForums.net
J
Jodes
Apologies if I'm posting in the wrong section!
I hope to replace an old broken analog central heating thermostat with a digital one.
Background: There are 4 wires coming into the box: yellow/green, blue, red and yellow. The yellow/green is tucked away, physically floating about. The other three are wired into the thermostat. The problem is, the new digital thermostat only has two terminals, which AFAIK should take the yellow and red wires. This leaves the blue...
How should I terminate the blue wire? I don't know if it's been disconnected on the other side. AFAIK, electrical insulating tape is bad, so how should I do it?
If the spare core is the neutral to the accelerator resistor, then it won't be needed and can be parked in a Wago or similar. If it's the N/C from the stat to a motor-closed valve then it will still be needed. You need to confirm this first, but in either case don't make any assumptions based on colour!
Thanks for both your input. I was lead to believe that the blue wire was only needed for older systems, but I'm just going to get a sparky in to do it now that I know I'm in over my head. Basically I don't know the blue isn't wanted. (Although now I know a Wago would be the tool for the job).
Just curious though...
1. If the blue is N/C, then by definition doesn't that mean it's not connected so not used?!
2. What is the motor closed valve?
3. And the accelerator resistor? Would that heat up the old thermostat? The new thermostat has features like prediction for steadier temperature regulation, based on previous cycles, which I thought would mean it doesn't have any accelerator resistor?
1: Sorry, ambiguous terminology! In context of switching, N/C = normally closed, opposite of N/O = normally open. Can also mean no connection, as you say.
2: Some types of motorised valve require a feed to close them, as well as to open, in which case each stat must return both N/O and N/C.
3: Yes, it would heat the bimetal thermostat at something less than the average rate of rise of room temp to reduce the lag in its response.
What ever you do ...don't cut it off, even if you don't need it. Like above make it safe using wago (similar) and tuck it away.
Reply to Terminating unused blue wire at the thermostat in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm trying to rewire an old plug. I've rewired a few in my time, but all have been with the post-2006 wire colours. I have this old welder...
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
