A
af1
Hi, was just wondering if anybody could tell me if TFT monitors are PAT tested seperately or tested with the computer?
Welcome to Electrician Forum. We started out on April 22nd 2006 and used Electricians Forums as our brand name which is an unregistered trademark.
.Depends on what make and model of PAT tester you use. Seaward Supanova has a IT test setting so should be ok to test.
I thought there was an exemption for devices using fully moulded IEC connectors
#i think thats the case you can test the lead without it being connected if the TFT is daisy chained off the PC PSU I'm not sure
