Discuss Thoughts on How To Price These Jobs? in the UK Electrical Forum area at ElectriciansForums.net
For PAT testing you need to set a price for "portable" appliances with a minimum charge, otherwise you could be doing a lot of fuel burning for a couple of appliances, and any fixed appliances need a separate set price - it can be a lot of bother accessing and isolating properly to allow proper testing.
A lot of the work will be wiring supply to boiler spur.
What do you think I should charge for this? I understand there's many variables but If I have a base
price to work from that will be half the battle.
Solid floors? chasing in or mini trunking? any spare ways in the CU? any RCD protection? main bonding in place. You need to go and look at a sample house, before making any solid prices.
You've the guts of £45-50 for materials for a CO detector, so £20-25 for labour, can you fit every single one in under an hour? Possibly going back to CU, and a new MCB. I'd be looking your price for replacement never mind installation.
The PAT testing at £50 may seem low until you have an hour or more drive each way and are there for an hour or 2.
Basically you need to work out what hourly rate you need to be charging, then estimate how many man hours for each task, add in materials and you'll get a more accurate price that you should be charging, then give that as the minimum or approximation.
Be realistic in estimations of work supply, if you pay yourself for a 40hr week at say £600, x52, then add in all your other expenses, insurance, any other costs like tools and vehicles etc, then divide that by 46, as you should be allowing for 6 weeks of no earnings to cover your own holidays, Christmas, Easter etc etc.
Now you need to estimate how many billable hours you can charge each week, remembering that you will have travel time between jobs, so for calculations we go with 30 billable hours, you can deduct a bit if you are all day or multiple days at one job, as you will be able to bill more hrs and have less travel costs. To stay competitive on larger jobs. If you know your weekly target then you can calculate a day rate for the bigger jobs.
By my calculations it's around £27-30 minimum to be able to get the same wage as if you were on the cards for someone else. So you either increase your labour rate to reflect the extra stress and admin work, or you add up to 30% on materials. To me the extra on materials is best as some folks tend to assume that your labour rate is actually your hourly wage, forgetting that it's covering a whole lot more.
Now these are rough estimates, only you know your expenses and desired target wage, so work that out and start from there.
Reply to Thoughts on How To Price These Jobs? in the UK Electrical Forum area at ElectriciansForums.net
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
Been asked to price for a job, customer is having attic done out so needs a few new circuits up there. Some more context I'm based in South Wales...
7K
Here we go again, another job that has had a council inspection, different council to last time but still perplexing. The problem with these jobs...
