Discuss Time switch for flouresant lighting in the Australia area at ElectriciansForums.net
M
MarkRC
hi all,
i am aware time clocks switch inductive loads, not capacitive, but would it be ok to switch 6 flouresant 5ft fittings? if not, could itbe done another way?:confused:
many thanks in advance
mark
thank you Jason, didnt think of a contactor. so you recon, if i go from the ccu to the timeclock to the contactor, then to the fittings?
Many thanks
6 x 5ft fluorescent fitting should be fine to switch directly from the contacts of the timer. Just depends on the rating of the switch and it helps if the fluorescents have electronic ballasts as well.
Reply to Time switch for flouresant lighting in the Australia area at ElectriciansForums.net
Hello all, I know this is very simple but I would like some advice please. I am installing a new circuit to feed 5 external floodlights. It is...
Hi folks, I’m new to the forum and it’s this issue that lead me here. So first things first. I was looking to wire in a Smart Relay at the rose...
Hi there I am getting someone in to change an outdoor switch and outdoor wall light (like for like). The old switch and light was covered by a...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
