Discuss two methods to verify a low ohm meter i think is not working properly? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Use a known length and size of cable (GN3 page 104 Table A1), apply temperature correction factor (GN3 page 105 Table A2), calculate expected resistance, null leads, test cable, record resistance. Is recorded resistance same as calculated resistance?, yes :- meter is probably ok. no :- test another known length and size of cable. Still not the same. Send meter away to be re-calibrated.
Reply to two methods to verify a low ohm meter i think is not working properly? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm currently in my year of my apprenticeship looking for some help with the 2 plate method (feeding the switch). I understand it up to the...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
