Discuss Using rotary isolators for switching loads on and off? in the UK Electrical Forum area at ElectriciansForums.net
Hi
Can you use rotary isolators to switch resistive loads on and off on a regular basis (talking 18KW load here)
I personally thought not, that it should be controlled through a contactor but I have seen another installation that is using isolators
thx
Bigfoots
Possible, but check the switching rating (as opposed to the thermal rating) of the isolator as it will be lower. There are different utilisation categories for different types of load and switching duty. E.g. AC20 rating is for isolating under no-load conditions, AC21 rating is for switching resistive loads.
Reply to Using rotary isolators for switching loads on and off? in the UK Electrical Forum area at ElectriciansForums.net
I haven't seen a lot of discussion on this subject and have questions pertaining to isolation where TN earthing is present and any peculiarites...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi there, (noob DIYer here!) Recently moved in and I have an inline extractor fan in my bathroom, which goes up into a crawl space in the loft...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
