Discuss Vehicle rear lights issue !! Help I'm lost in the Auto Electrician Forum area at ElectriciansForums.net
Recently purchased a Nissan qashqui both rear lights ,indicators etc work however when u have foot brake and left indicator on the lights at rear left are xmas tree as they say and indicator is faint but repeater goes at fast pace
I thought bad earth ? So
I have swapped the circuit boards from rear right to left and vice Versa and not doing it ? Everything works perfect !! Weird
Unfortunately the cluster boards are specific for each side due to shape so can't leave it as working
anyone got an idea ?
Thanks in advance
Sounds like a bad contact on the board which unconnecting and reconnecting has cleaned up a bit.
There's a good chance it will work if you put back correctly now.
Some switch/contact cleaner spray (maplins for instance) may be a good idea.
Hi there I have changed it 3 and 4 times and any time I put correct circuit board on ns rear and indicate and press brake it happens. This is side where earth is in body also noticed that the drivers side rear lights flicker slightly also
Was the vehicle bought with this fault or have they been working ok , or have you just noticed it , or was your attention drawn to it?
The fault may have been there for some time .
How old is the vehicle , and has it has it had a tow bar fitted?
Are the lamps (bulbs but I am frightened to say that) all correct for the vehicle?
Ps . I do not think you are far away with an earth fault or water ingress.
Check if the vehicle has CanBus controlled lights. It is also worth testing the ground,at each cluster position,and also,if the correct lamps are fitted in the correct manner.
An incorrectly jammed in 5/21w,or a single contact lamp in a dual contact receptacle,can give the symptoms you describe.
All the bulbs are correct. I have just purchased the vehicle and noticed it when braking and indicating left , I have taken clusters off and noticed right rear lights flicker also.
It's a Nissan qashqui 2009 not fitted with a towbar
Ok guys I have Sussed it out the 4 pin connecter plug I noticed the black one contact in plug seemed wider than rest , stripped the plug , used tweezers to align contact points and. Bingo.
Problem solved !!!! to the next time
cheers for the update. next time buy a toyota. :p:p:p
Reply to Vehicle rear lights issue !! Help I'm lost in the Auto Electrician Forum area at ElectriciansForums.net
My 2003 Toyota Echo has two back lights in the instrument cluster. One of the lights would flicker if I hit a bump or something. I swapped the...
Hi all Looking for some guidance on how to go about wiring up the lighting that was fitted to my Iveco daily van. Previous owner had fitted and...
I need some wiring help. I have been putting new switches on throughout the house & have had no issues with the Y block backed ones. Just copied &...
Hello, Total newbie here and as you can tell from my name..... I'm definitely not an electrician. I've done a bit of electrical hackery in the...
7K
Hello All, im having some issues with my wifes 2005 Micra S. she had reported that her front wipers had just stopped working. after taking a...
10K
