Search the forum,
Discuss Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
Opening a can of worms here guys. Question is do you want to comply with the regulations? Click 100? Yes, looks good BUT no cable restariant therefore a NO NO! See more details on other boxes on
COMPARISON TABLE
There actually arent many that will comply!!
Whoever compiled that comparison judged by looking at and not actually using the wagobox, I find I need a screwdriver or pliers to prise the lid off a wagobox especially when its loaded, unless I fancy loosing a load of skin off my hands as they are damned hard.
Trouble is that you can remove the cables (live wire?) from the wago connectors without a tool! Safe location is obviously a factor but you choose if you want to argue the case with HSE is someone opens one without a tool and fries!
well wago say they are 17th compliant
Well I guess they would?! I will gladly retract and apologise if you can point me to the part of the regs that gets them out of jail. Here's my take on the regs:
Read BS 7671 chapter 41: Protection against electric shock:
412.2.2.3 ......,."THis insulating barrier shall be removable only by use of a tool or key"
416.2 Barriers and Enclosures....416.2.4 "Where it is necessary to remove a barrier or open an enclosure ..... this shallbe possible only: i) by the use of a key or a tool."
The only way I can see it complying is: 417.3 Placing out of reach. I know my NICEIC inspector and lecturer for part P had pretty stron views on when this rule can apply. Also, see 417.3 "NOTE: protection by placing out of reach is intended only to prevent unintentional contact with live parts."
ANd 418 = under the controll of skilled personal. So I guess this could be what WAGO mean when they say it complied?
Have I missed anything?
I got a load of wagos a little while back and was using them on everything.
I have since gone back to crimping most things though or good old screw terminals! I personally like the idea of knowing that when I go off site there is no way its going to come undone. Although having some wagos in the van is a godsend sometimes.....
As for downlights, I use the click conectors whilst 1st fixing and then wire up the downlights to the other side of the connector at home on the sofa watching tele, thats my sort of working conditions!!! Then when you go back to 2nd fix you just have to test and then plug them in.
By click I assume you mean the click 100. Problem with them is that there are no cable restraints so may not comply if just pushed through ceiling. Like your work methods though!
Can I revive this thread ...
Fitting 18 fire-rated downlighters to kitchen (cfl lamps). Have 5 rows of lights and got 5 Ashley downlighter junction boxes. Was planning T&E from lightswitch to first Ashley, then looping all 5 Ashleys together with T&E ... then running T&E tails from the Ashleys to each downlight connector block. Max 4 downlights per Ashley.
If all Ashleys are close to a downlight hole with enough slack to pull through the hole is this classed as accessible?
Also, is it OK to run standard 1.5mm T&E to each downlighter or do I need heat resistant cable ... some posters said they use heat resistant flex to the downlighter?
Thanx
Well if your going to use something like the Ashley J501 downlighter Junction box then yes you need to keep these accessible and yes it is deemed accessible to be able to access them through the downlight hole.
If you go with the Ashley J803/4 and you design this install to the BS 7671-2008 1st amendment then as per regulation 526.3 (vi) you can have these classed as an inaccessible joint and not worry about it.
It is OK to terminate T+E into the downlighter, espicially as your using CFL, even though they still produce heat, certainly not as much as halogen lamps.
I have to be honest I would always terminate a downlighter with Heat resistant flex just for safety. You could of course fit some heat proof over sleeving on the T + E if you wish.
I have to admit though there is nothing wrong with having the 5 lights on the one JB, it's going to be a nice tight fit in that single JB, at a minimum 6 cables, and if you a fault on a fitting, and need to remove it to say buy a replacement your going to either have the other 4 lights off, or make that on leg safe, whereas a JB for each light is a lot easier.
Reply to Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
