Discuss What RCBOs are compatible with these? in the UK Electrical Forum area at ElectriciansForums.net
FatAlan
Trainee
Supporter
Looking to add an additional circuit to this board. What currently available brand of RCBO’s are going to available. I suspect with the Havells shown there are already two brands mixed in? What’s the other brand with the black oval and red triangle symbol?
The black oval and red triangle is 'Control Gear direct'. They are now called Lewden and no longer have the same symbol.
Ignoring the obvious incorrect mixing of manufacturers components, those Havells RCBOs don't look like they fit at all well, the cover looks very distorted and they seem to be in at an odd angle.
It gets absolutely ridiculous with all these different types of gear.
At least, when it was fuse wire, you knew what you were getting and the connections were decent and things fitted. ? even if some couldn't tell what the rating was? or couldn't tell the difference between fuse wire and solder?
If you ran out of fuse wire , you could just strip some 1mm
Reply to What RCBOs are compatible with these? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
I was recently called to a domestic nuisance tripping job, dual-RCD Wylex board with one of the RCCBs tripping intermittently, mostly during the...
6K
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
I need to replace two AFCI breakers on our main circuit panel. I have replaced and added breakers to our sub-panel several years ago. When I...
