Discuss What’s the best way to link 2 BG Outdoor IP66 Rated Enclosures in the UK Electrical Forum area at ElectriciansForums.net
But not IP66. Maybe add some sealing washers?Threaded coupler and 2 bush nuts
How far apart are the enclosures?Is there an M20 male to M20 male fitting to position the enclosures close to each other, or something neater than Copex?
They will be right next to each other could be almost touchingHow far apart are the enclosures?
Almost touching, or as close as the “connector” will allowHow close?
Thank you all for your thoughts and input, very useful.If the sides are respectably flat around the point at which you want the connection, put a plate or 'giant washer' of paxolin / tufnol / suitable plastic between them, with 20 / 25 / 32mm hole in, and conduit bush and lockring / nut right through the lot. Screw one box to the wall firmly, leave the other free. Coat both sides of the plate with silicone, offer it and the other box up, snug up the conduit bush and then screw the second box to the wall. That will allow the conduit bush to clamp the sides of the boxes together without distorting them. The large area of silicone sealing the plate to each box will give you a reliable IP68.
Why do they need linking?What’s the best way to link 2 BG Outdoor IP66 Rated Enclosures
Reply to What’s the best way to link 2 BG Outdoor IP66 Rated Enclosures in the UK Electrical Forum area at ElectriciansForums.net
