Discuss working out volt drop in the Electricians' Talk area at ElectriciansForums.net
I wasn't having a go at him Shanky :) , just curious as the thinking behind it that was all :) , I must admit that I had dark thoughts of someone thinking a source/supply RCD may somehow negate possible bonding issues with PME, as I have heard this before from someone who should have known better :)
It's suppled from a pme system
rcbo at supply end and rcd at garage end but over the top but it's not going to give any nuss tripping.
4mm fro radial (got in in the van )
Over the top is one one thing but wasting money and having no discrimination of 2 rcd in series thus does not comply to regs is another, yes its not going to give nuisance tripping par' ce but its poor design from a professional all the same.
No, it won't. Or am I missing some of what you missed?
I have thought for a moment and I cannot see why an ordinary RCD test button would trip an upstream RCBO. Pray tell...
just out of interest, can anyone quote a reg. that forbids 2 30mA RCDs in series?
Right, I have had a thought :), and it seems maybe you are correct and I was wrong for this scenario being that the RCBO is upstream and the RCD is downstream, however if the RCBO and RCD were the other way around then it trips both devices for some reason, maybe something to do with the functional earth on the RCBO ?
I know this as a fact because I once was testing a custom built SP DB (by the firm I as working for), and all of the test rigs were in use so I used a normal socket outlet and "widow maker" lead to power this DB up to check the metering etc., anyhow I accidently caught one of the test buttons on one the many RCBOs fitted to this board and promptly tripped out the supply RCBO for this supply too, the howls of protest from a co-worker whom was using a computer powered from this supply revealed this lol :)
Reply to working out volt drop in the Electricians' Talk area at ElectriciansForums.net
Why is this still a thing, just done a quick calculation with the TLC volt drop calculator and if its a non lighting circuit the recommended size...
I am trying to understand 3 phase volt drop. I understand single phase VD. Lets say we have a 70 meter run of 35mm, 5 core cable from the supply...
Hello, New trainee electrician so sorry if this is a dumb question I feel confident with calculating the volt drop for a ring and radial circuit...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
I'm getting a little confused about volt drop and 24v. I want to fit an LED strip light. 8m of lights 7w/m. It would be easier to have the 24v...
5K
