That started with a smoke dropping in the oil trays under the escalators. Bloke with me only wanted to be a key holder to he could search the trays for money while he was making off piro ends.
It was caused by a handrail overheating due to non maintained bearings, the reason why the fire spread so quickly as the handrail was still turning. A fire in an escalator pit would only affect that area, and take a lot longer to spread.
Are the camera,s not monitored by a central control room with a bms system, if so it would be feasible to control the maintained and non maintained lighting through the bms.
The inrush of air pressure by the trains, was the final nail....all communications & cctv are local and linked to central point. Linear zoned heating cable is now installed under all escalators. Alot has now changed since kings cross. Zoned localised dampers/extraction, Phased evacuation by priority platform area. Hopefully serious lessons have been learnt.
Anyone would think you knew what you were talking about Dave. Which you clearly don't because you're daring to post something that Thomas didn't :)
Reactions: 2 people
Hopefully the biggest lesson learned would be a strict escalator maintenance regime, which was not the case at the time, handrails rubbing over seized bearings create a lot of heat and the heated particles of the handrail form a "cloud" which ignites in a fireball when a certain temperature is reached.
Wooden frame, oiled bearings, human dust, clothing fibres & bad maintenance .....Fire just waiting to happen
That's sobering and frightening.
I passed through there a few days after (I don't remember how many now. I may have been going to a job at Earls Court) and it was frightening then even after the event.
It really was an accident waiting to happen and all in the name of saving a few pennies I think.
If there weren't any prosecutions made (again I can't remember) then there damned well should have been.
I really do not understand why I would lie about this. What is the point? I was asking for alternative ideas as I do not 'know it all'.
I am a specialist railway contractor. Can I ask what you do Trev. I am interested to know what gives you the right to question my word?
You're banned as I write this but what makes you think you're above questioning?
Who tf are you? The bloody queen? The arrogance in the highlighted question is breathtaking even by my standards.
Fyi I'm self employed, I do a mixture of works, in the past I've even worked on the railways so I know people in the industry, some of whom are on here. They're calling bull**** too
You can say that again , there should of been jail sentences handed out for that. The whole of what industry that is left seems to cut corners and miss priorities.
Its worse now, the time allocated to carry out maintenece on a lift. Would allow getting the motor room keys and giving them straight back.
Switching ideas
Guest125,
elevate,
