Discuss ACbling for linked fire alarms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Pat H
Domestic property (mine) having loft conversion.
So need linked fire alarms. One on each landing so 3 in all.
I'm going for the AICO Ei2110 multi sensor alarms.
Was looking at the radio link bases and then link them all up to a dedicated circuit to the CU
(not going to use lighting circuits)
So original plan was to just run 1.0m T&E to those alarms in dedicated cables.
dedicated RCBO to feed them? (the internal batteries last for 6 months so loss of supply isn't really an issue)
Then it occurred to me maybe that cable should be a different colour? and then why not get a 4 core cable and run the control signal down the extra core.
Thoughts?
If they are are going on the same circuit I'd just use 3-core and earth and not bother with the radiolink. Radiolink is great for retrofitting, as the alarms can be on different circuits. Bit pointless (and more costly) if you are linking all the alarms anyway!
Hi Pat, sounds like LD3 grade D system and that does not require FP cable or cable with a different colour. Inspector Gadget may look for the sticker in CU identifying that which cct has smokes are on it. Just a suggestion - if your Building Control have not written down what is required, try to get their agreement to your proposal in writing as they have the right (apparently) to ask for more than BS5839. Also, if you've a a solid fuel stove / log burner I understand it's now compulsory to have a CO detector in that room.
I can understand why you may need radio bases if you are starting from scratch.
If it is not to difficult , I would go with Kingeri.
I've got to run lighting and RFC to the loft space from the CU anyway so its no issue to run a dedicated feed.
Yes LD3 grade D is listed in the drawing specs. But I'm contact with Building control so can run it by them first.
As it will be a separate circuit I may as well go with a different colour anyway.
So does it make sense to run 4 core and use one for the control?
PS be good if I could correct the typo in the Thread topic...
Thanks yes got that handbook. very helpful.
Three core and earth is pretty standard to be honest.
For more info go to the Aico site and get yourself the free installer books on smokes and co detectors .
They are very good and toolbox size.
Yes, 3 core+CPC (6243Y) is usual.
Also, Aico have a contractor's handbook avail from their website.
Shame you can only get that in grey. I've found similar in red but silly prices.
No requirement to be a different colour for my install so I may just slide heat sleeves on at all the ends over the outer to make it clear they are different.
Why do you want it a different colour? It really isn't necessary! And I would seriously consider putting them on a lighting circuit! I know you can put them on a dedicated circuit, but putting them on a lighting circuit is actually far more preferable, even when starting from scratch (in my humble opinion).
Why? As far as I remember, the vanilla flavoured Aico alarms have live, neutral & interconnect. As others have said, when I had an extension done a few years ago now, smoke alarms appeared on the drawings all over the house, not just the extension. That said, if I was doing it again I would put more in....as long as you have one of those control switches!
No need for Co2 detectors.
Will look at control panel but the multi sensor alarms are supposed to trip less.
Around £30 so not bad. Can't see the need for the locate button. I know where I'll have installed them. I don't expect them to wander :)
Well my organised mind likes the idea of a separate feed just for the alarms. Marked up in the CU.
I already have 2 lighting circuits and will have 3 when the loft cabling goes in so each alarm would be on a different lighting circuit so a different RCBO in the CU.
That does mean if any one circuit fails the other 2 will still be on. But with the modern alarms having 6 month battery backup power failure really isn't a consideration.
If I use the lighting circuits I can't use a control wire easily so would have to go with the radio links.
I think you are over complicating matters.......... hugely.
I certainly am. But that's because the build is still 3 months away and I have time on my hands to plan and consider. As I'll be doing it myself and there are more cable runs to go in the only real difference is the cost of the extra cable and an extra RCBO. Still got 3 months or more to ponder it...
Yes my house.
Why on earth would you specify radio link bases at a design stage!?
Feed them from their own RCBO or a lighting circuit - up to you, but for gods sake just link them with some 3 core and earth!
The control switch, is
Don't think you understand the purpose of these control switches. If you have more than one interconnected alarm, when one sounds, they all sound. Invariably or hopefully, when they do sound its because of a false alarm. You can press the locate button and it will isolate all but the alarm activating, to aid you narrowing down the activation. You can also use the switch to test all the alarms, rather going round testing each one individually, with a step ladder. You can also use the switch to silence the alarms, if you can't clear the false alarm, burnt toast syndrome. In the case of a real activation, you won't be hanging around using the control switch. ;)
A very useful device IMO.
PS If you do use radio links, there is a radio link control switch.
Thanks I saw the info on the radio link. Yes it does look handy.
Reply to ACbling for linked fire alarms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
On this commercial building we are refurbishing it has the above fire alarm panel which I think is pretty much brand new, I'm not even sure it was...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
This isn't really an electrical issue as such but I know you guys are pretty tech savvy and familiar with all the latest and greatest...
A recent conversation with Aico technical enquiring to maybe fit wifi devices in a commercial environment, workshops, business units...
