May be they are trying to put things off, waiting for their price hike ;)
Reactions: DPG and marcusone
How does the meter detect the relevant change over time ?
is it built into the meter as a clock function, or does it use a radio signal ?
we had one some years ago that would not change over, after much tooing and rooing, it was found that a recent new build blocked the signal in the background of Radio 4
if they cant sort it get a contactor with a time clock built in
Hi Jurassic. Thats just it. I'm know very little about current meters but assumed when we asked for an E7 meter to be installed that this one would do the off peak switching. Beginning to think they just keep giving us a 24hr supply with a "control" supply on terminal 5 and we have to install our own timer and contactor. Reluctant to do so if the meter is capable when programmed properly. Last resort if we have too can you recommend a contactor /time clock. Thanks all for your input really appreciated.
A contactor and timer won't help at all, the problem is that the meter is not set up for E7, therefore they are being charged a flat rate 24/7
Th contactor and timer would switch the heaters on and off, but they would still not be on an E7 tariff.
Reactions: marcusone
Hi All. Just an update...... finally resolved. Unbelievable amount of messing about but eventually someone at their end said the meter is E7 ready and it just needs the correct key to activate it . Key arrived and sure enough its all ready to roll. Thanks for the reassurance guys was beginning to doubt sanity!
  • Winner
Reactions: Richard Burns
Good man for giving us an update ......................... we come across these difficulties with the suppliers on a regular basis ................ like many things they have dumbed down the knowledge of the people in the field and on the end of a phone.............
Most of them are completely hopeless......................
Bristol
New E7 meter. Do I still need a timer for storage heater circuits?
marcusone,
Octopus,
