- Mar 21, 2011
- 13,191
- 11,409
- 18,688
- United Kingdom
- Retired Electrician
We have mentioned on here before the perils of buying a new build property!
Downstairs before any carpets go down get yourself one of these saws... set to the right depth you can easily cut out the floorboards if they are the tongue and groove click ones.
Not all new builds are the same, mine been built by quality tradesperson, so get stuffed.
As for lifting glued chipboard, I'd rather go to the dentist and have all me teeth pulled; there's at least two left.
