John-
Jan 13, 2019
198
42
103
Uk
Going to be fitting a three phase SPG at the origin of a supply. I have solid coper standard 25mm tales that come out of the head into an isolator and then fine stranded 25mm single insulated cables that run from the isolator, within flexible conduit to the Dis boards.
They have used a crimp that ends in a flat blade to terminate the fine stranded cable - thus allowing them to have multiple tales of that isolator. Am after some more of these but cannot find them anywhere - no I did not take a picture, i didn't think they would be that that hard to find! They are not a boot lase crimp, as the termination is flat to make installation the into contact easier.
Any ideas what these are please?
Cheers
John
looking at the dimensions, 7mm blade - seems skinny for a high load. Anyone used anything like these before on large CSA cables?
I'd guess the actual contact area is probably greater than you'd get with a standard 7 strand cable
Reactions: John-
When I saw the thread title I thought Shimano clipless pedals.
Uk
SPD Fitting Cable Advice please
Electrical Tools and Products
John-,
Mike Johnson,
