- Aug 12, 2017
- 14,334
- 20,733
- 3,557,381
- 51
- United Kingdom
Pub kitchen I was doing PAT for, opening at 12 today. They have had to reconfigure where everything sits, so new location for double deep fat fryer is too far away from sockets.
Double fryer is basically 2 x 3kW fryers in one unit… two leads, two plugs.
I’ve told him not to plug both onto same double socket which is nearby… partly 24 amps going through one point, and partly I know the double socket is a spur, and one socket on it is powering the extraction fan.
So, just for this weekend, a suitable extension lead is needed to run one half of the fryer.
No one nearby stocks plugs and sockets to make up my own, so I saw this. Will probably shorten it, 3m at most needed.
Do you think this will last long with a 3kW load on the end?
www.screwfix.com
Masterplug 13A 1-Gang Unswitched Extension Lead 10m - Screwfix
Order online at Screwfix.com. Heavy duty 1-socket extension lead. FREE next day delivery available, free collection in 1 minute.
