714gold714
Hello there
Currently first fixing a small annix building basically customer is having this annix built in the garden and is requiring 2 BT telephone points and would like to be able to use internet broadband from both points.
My question is do I run a telephone cable from existing house to new annix and also run a cat 5 from router in existing house or is there a easier way?
All help appreciated
Run a 3 pair telephone and 2 cat5, even if both cat5's aren't used now its always handy to have a spare.
Reactions: 3 people
The broadband will be fed from the router via CAT 5, unless they go for 2 telephone lines and a separate router in the annex - which is very unlikely. As monkey says, run spares while it's easy to do so. Daz
wireless ? - I know it does not help you but why bother wiring anything for broadband or even phones. Only reason to cable nowadays is for AV
cant beat good old wired connections
when refurbing propertys with fit out the house with cat5 / cat6 points everywhere
Reactions: 2 people
Every rewire i do i recommend wiring cat5 everywhere all back to a central location, to tv points, places where a computer may be or anywhere really, its so cheap and easy to run, all you need is one router and patch panel then to your points for whatever you need and put in wireless access points if its a big place and the signal is weak
My Dad bought some device for his motorhome, about 70 quid, got a big anenna (or if youre German saying it in english, " un-tunna")on it, picks up WiFi for hundreds of metres around...I was sceptical until he showed me, it picked up about 20 different signals, its proported to be for motorhomers so they can login into wifi provided for them but I can see it might be used otherwise.....
Reactions: 2 people
My Dad bought some device for his motorhome, about 70 quid, got a big anenna (or if youre German saying it in english, " un-tunna")on it, picks up WiFi for hundreds of metres around...I was sceptical until he showed me, it picked up about 20 different signals, it proprted to be for motorhomers so they can login into wifi provided for them but I can see it might be used otherwise.....
What a great idea!
Any wireless equipment that has a removable antenna can have it's performance improved by using a higher gain antenna although doing this may mean it is operating at a greater EIRP than allowed by the regulations
please help telephone and broadband new build annix wiring
714gold714,
SPARTYKUS,
